Hello, I have some issues on my d16y8 head gaskets, it leaks oil on the edge of between the head n the blocks right below the upper coolant hose housing, I have checked and replaced for other possibilities such as distributor orings, sensor under the distributors but still no luck, I even replaced the gaskets to a original d16y8 3 layer metal gaskets but it still leaks oil on the edge, what could be wrong with it?please help me???
Did you have the head re-surfaced prior to putting it back on? Should take a flat-board sander with some mild grit to the block deck as well.
did you use new headbolts or are you re-using the old ones?
torqued to spec?
Nope I nvr mill the head before as I never had any overheating problems, I even check for head bends but there are no bend at all, I just clean the surface and install the new stock y8 metal 3layer HG
Remove the head and have it re-surfaced. Just the act of removing an aluminum head can cause it to warp due to the repeated heat cycles it goes through.
Also surface the deck with a flat-board sander. Re-assemble with a new gasket. Don't use any sealer.
