this may be a dumb question... is there a difference between an automatic and a 5spd harness. besides the tranny plugs could it still be used in a 5spd with no problems? thanks.
I am building a EF I have a D15b2 block with a D16y8 head.
I have the engine together and in the car already.
I ended up using a gates water pump kit with y8 timing belt.
When i went to time the engine it looked ok but I assumed i
could compensate with the dizzy if i had an issue ( I was wrong)...
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
