Hi, I’ve been searching a bunch of forums and have not found any answers that solve my problems.
So the motor is a D16Y8 with a P72 ecu. I don’t have a CEL as the motor is in a classic mini. I have hooked up a light to pin 13 on plug A to ecu (Malfunction Indicator Light) according to things I’ve found on forums. I have also tested solenoid and it clicks, I’ve hooked up a light to the vtec solenoid and it doesn’t turn on.
Last winter I changed the intake manifold to allow for better fitment. (Again it’s stuffed into a classic mini) since then I don’t think vtec has been engaging. There are no other issues with drivability or any weird behaviour.
I also have validated it gets oil pressure at the solenoid (forgot to re install vtec solenoid before starting the car... it was quite the fountain of oil!) and my oil level is good.
Any help would be appreciated. Thank you
