1 - 6 of 6 Posts
So I have a d16z6 in my Sol, and bought a Trans from a 99 civic with the d16y8. Everything fine and dandy, till I found out out the connector on the z6 harness is a little difference then the y8 VSS. I did notice both are 3 pin sensor so cutting and splicing is an option. However the question i'm really after is, can I just take the z6 VSS and put it in the y8 trans??? There really is a huge lack in any google help on this one, so any info greatly appreciated.
It looks like the the y8 is a 1 hole mount and the z6 is a 2 hole mount. i found a little but unclear help with searching it some1 said only use the one hole on the z6 sensor to mount it
y8 vss
z6 vss
when you compare the pics, theres clearly a good difference between the 2 though. the y8 has one hole and the z6 has 2. But i'll take your word for it, i'm sure i'll understand once i pull it out to swap it
The Z6 has only one mounting hole. In the picture you posted above the string for the tag is ran through it.
1 - 6 of 6 Posts
