1 - 6 of 6 Posts
So after filling up the radiator twice in two weeks I decide to look deeper. The head gasket was replaced 1 year and a half ago. So on a cold start I'm getting white smoke, running crappy and loosing coolant. With the radiator cap on the first turn it runs good. After taking intake off there is coolant on the intake valves of number 4. So I don't know if head gasket cracked head or coolant passeges in the intake
yep intake manifold - make sure you replace it with a gasket that has a brass ring around the coolant jacket. Maybe give a thermal intake gasket a go!
Well if you open the throttle. It's all wet
at the base. No I the throttle body and the iac has coolant going to it?
1 - 6 of 6 Posts
