hi guys! well i did a comp test, it was 190 on all pistons, I was like cool, ready for turbo ya! put all plugs back in and wires,then started the motor, it started knocking and misfire, then smoke out tailpipe, piston 1 misfire, now has 0 compression in that hole, what did I do??
no theres nothing, inside, its burning mad oil now in that hole, could I have broke a ring? due to no oil psi when cranking,wth
ej8
Say what you did again.
You took a running car and did a dry compression test?
Disable fuel and spark?
And then you put the plug and wires back in. Reable fuel and spark. Then started it up and it misfire really bad?
Are the spark plugs in the right order?
You say its smoking alot is it blue, white, or black?
If you pour oil down the cylinder for a wet test and pour to much you might have bent a valve which would cause low to no compression in a cylinder.
