1 - 4 of 4 Posts
Hey guys I'm new here and was wondering I'm doing a d16y8 build and what rods would be best to go with ycp high compression pistons? Preferably ones that I dont have to grind the block.
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
That's been talked about before so new convos about the subject are allowed.
You don't need aftermarket rods. That the issue with searching stuff.you don't know about yet. You need to know what you are looking for.
Well you are going all motor so I'd use stock d16 rods with arp's installed on them. Also the pistons will work with stock rods. Due to the floating pin on aftermarket rods
Sorry Slo, i didnt read it as he was looking for WHERE to buy anything but was looking on info on WHAT to buy and what is needed and what type of rods could.work that don't require block notching.
meh, helped him on his way around the interwebs. maybe 1 rabbit hole will lead to a mole hill?
1 - 4 of 4 Posts
