1 - 20 of 24 Posts
So I'm building a d16y8, parts being used are as follows
walbro 255 fuel pump
440 eagle talon injectors(possibly) may go bigger
Y8 block
stock crank
vitaras and custom length rods (0.007 ptw 75mm)
0.19 top end ring gap
0.21 second end ring gap
acl bearings, (have to look for clearances)
stock ported oil pump
Head (undecided)
hx35 turbo, ram horn, depending on funds maybe twin scroll
OEM head gasket
AEM cam gear
possibly bisi level 3.4 cam and supertech vavle train
Stock tranny, still looking at what clutch and flywheel to get...any advice?
looking to make 350-400hp
Possible stand alone hondata s300 ecu, found one for cheap!, if that falls through, just chipped p28 ecu tuned with crome
just finished notching my block! there a little rough area in the piston skirt travel, is that bad for the skirts? how should i go about smoothing that out? any input or advice with the set up feel free to mention. pics will come soon!
Also still trying to find what a good bearing clearance is, and also wondering if 0.007 ptw with 75mm bore is safe to run.
try a walbro 190 instead of the 255. most of the civic 5th and 6th gen stock fuel pumps handle 300hp no problem with a simple fuel pressure regulator and a new hose from the tank to the filter to cut pumping losses down a bit.
why 75mm vitaras? that is stock bore. you want a fresh bore on a higher horsepower build. Stock is fine if maybe 200-250. I enjoy a fresh slate when going for more power though.
have a shop do an alignment bore to 75.5mm and also have them open up the oiling holes a little on the crank.
research oil pump porting. stock oil pump could use some help pumping. dont shim unless you go crazy and open up every oil hole you see
just going to stick with std bore, I've seen good builds with std bore, going to get the block honed however. specs are in first post
75mm bore (0.007 ptw)
0.19 top ring end gap
0.21 2nd ring end gap
anyone help me out with what my main bearing clearances should be? and re a sure that a 0.007 ptw is fine? i've read that 0.003 to 0.0025 is fine.
I would bore out to 75.5mm and go with 255 walbro
lol, im confused with what to do, I've seen good builds with std bore, but Im being told to do the bore and i understand its a better idea to, hmm lol, and to be honest theres no reason for me not wanting to do the bore lol, just if i don't have to why do it?
I guess it personal preference, it gives alittle more power. One thing I would maybe consider would be 3 angle valve job after your head is done.
i've tried to search for rod bearing clearances, but cant seem to find anything. anyone have a link with anything to do rod bearing clearances? such as safe clearances for 350-400hp? thanks!!
Dropped the block off to get honed and hot tanked!:) should be back in a couple days! decided to stick with the std bore. and could anyone help me out with connecting rod bearing clearances? and if there is any clearances needed for the bearings the crankshaft sets in on.
Bump you self to the google search.
SOHC General engine overhaul & torque specs
96-00 Honda Civic
General
Cylinder compression pressure
Standard………………………………...............184 psi
Minimum……………………………….............135 psi
Maximum variation between cylinders…………28 psi
Oil pressure (hot)
At idle………………………………..................10 psi
At 3000rpm………………………………..........50 psi
Engine block
Cylinder bore diameter
Standard………………………………...............2.9530 - 2.9540 inches
Service limit……………………………….........2.9560 inches maximum
Cylinder taper limit………………………………...........0.002 in maximum
Cylinder out-of-round limit……………………………..0.002 in maximum
Block deck warpage………………………………..........0.004 in maximum
Pistons and rings
Piston diameter
Standard………………………………................2.9520 - 2.9524 inches
Service limit………………………………..........2.9516 in maximum
Diameter measurement point (from bottom)……………..13/64 in
Piston-to-cylinder wall clearance
Standard……………………………….................0.0004 - 0.0016in
Service limit………………………………...........0.002 in maximum
Ring groove clearance
Top compression ring
Standard……………………………….................0.0014 - 0.0024 in
Service limit………………………………...........0.005 in maximum
2nd compression ring
Standard………………………………..................0.0012 - 0.0022 in
Service limit………………………………............0.005 in max
Ring end gap
Standard……………………………….................0.006 - 0.012 in
Service limit………………………………...........0.024 in max
Standard………………………………..................0.012 - 0.018 in
Service limit………………………………............0.028 in max
Oil control ring
Standard………………………………..................0.008 - 0.028 in
Service limit………………………………............0.031 in max
Crankshaft and connecting rods
Endplay
Standard………………………………...............0.004 - 0.014 in
Service limit……………………………….........0.018 in max
Main bearing journals
Diameter………………………………...............2.1644 - 2.1654 in
Taper………………………………....................0.0002 in max
Out-of-round……………………………….........0.0002 in max
Runout………………………………..................0.001 in max
Main bearing oil clearance
Journals no. 1 and 5
Standard………………………………................0.0007 - 0.0014 in
Service limit………………………………..........0.002 in max
Journals no. 2,3 and 4
Standard……………………………….................0.0009 - 0.0017 in
Connecting rod journal
Diameter………………………………................1.7707 - 1.7717 in
Taper………………………………......................0.0002 in max
Out-of-round………………………………..........0.0002 in max
Connecting rod bearing oil clearance
Standard………………………………..................0.0008 - 0.0015 in
Service limit………………………………............0.002 in max
Connecting rod side clearance (endplay)
Standard………………………………..................0.006 - 0.012 in
Service limit………………………………...........0.016 in max
Cylinder head and valves
Head warpage limits
Max without resurfacing…………………………0.002 in
Service limit………………………………...........0.008 in
Cylinder head height………………………………...........3.659 - 3.663 in
Valve seat angle………………………………...................45 degrees
Valve face angle………………………………..................45 degrees
Valve margin width
Intake………………………………......................0.026 in max
Exhaust………………………………...................0.037 in max
Valve stem diameter
Intake
Standard……………………………….................0.2157 - 0.2161 in
Service limit………………………………............02146 in
Exhaust
Standard………………………………..................0.2146 - 0.2150 in
Service limit………………………………...........0.2134 in
Valve guide inside diameter
Standard………………………………..................0.217 - 0.218 in
Service limit………………………………............0.219 in max
Valve stem-to-guide clearance
Intake
Standard………………………………..............0.001 - 0.002 in
Service limit………………………………........0.003 in max
Exhaust
Standard………………………………...............0.002 - 0.003 in
Service limit………………………………........0.004 in max
Valve stem installed height (measured from tip of valve)
Standard………………………………..............2.093 - 2.112 in
Service limit………………………………........2.122 in max
Valve spring free length
D16Y7.……………………………...............................2. 28 in
D16Y5
Intake……………………………….....................2.22 in
Exhaust………………………………..................2.28 in
D16Y8
Intake……………………………….....................2.28 in
Exhaust………………………………...................2.31 in
General
Firing order………………………………......................1-3-4-2
Cylinder numbers (front to rear)………………………..1-2-3-4
Bore……………………………….................................. 2.95 in
Stroke………………………………...............................3 .54 in
Displacement………………………………...................97.0 cubic in (1.6 liters)
Camshaft
Endplay
Standard………………………………..............0.002 - 0.006 in
Maximum………………………………............0.020 in
Lobe height
D16Y5
Intake
Primary………………………………...........1.5129 in
Secondary……………………………….......1.2674 in
Exhaust………………………………...............1.5269 in
D16Y7
Intake………………………………..................1.3897 in
Exhaust………………………………...............1.4678 in
D16Y8
Intake
Primary………………………………...........1.4479 in
Mid……………………………….................1.5068 in
Secondary……………………………….......1.4592 in
Exhaust………………………………...............1.4964 in
Runout
Standard……………………………….............0.001 in
Service limit……………………………….......0.002 in max
Journal oil clearance
Standard……………………………….............0.002 - 0.004 in
Service limit……………………………….......0.006 in max
Oil pump
Rotor-to-cover clearance
Standard………………………………............0.001 - 0.003 in
Service limit………………………………......0.006 in max
Tooth tip clearance
Standard………………………………............0.001 - 0.006 in
Service limit……………………………….....0.008 in max
Outer rotor-to-pump body clearance
Standard………………………………............0.004 - 0.007 in
Service limit………………………………......0.008 in max
Torque Specs
Camshaft bearing cap bolts
6mm bolts………………………………........104 in-lbs
8mm bolts……………………………….........14 ft-lbs
Camshaft sprocket bolt………………………………..27 ft-lbs
Crankshaft fluctuation sensor mounting bolt…………104 in-lbs
Main bearing cap bolts
Step 1.……………………………...................18 ft-lbs
Step 2.……………………………....................38 ft-lbs
Connecting rod bearing cap nuts………………………23 ft-lbs
Crankshaft pulley bolt
1996-earlier………………………………......130 ft-lbs
1997-later
Step 1.……………………………...............14 ft-lbs
Step 2.……………………………...............Tighten and additional 90 degrees
Cylinder head bolts
Step 1.……………………………....................14 ft-lbs
Step 2.……………………………....................36 ft-lbs
Step 3.……………………………....................49 ft-lbs
Step 4.……………………………....................49 ft-lbs
Driveplate-to-crankshaft bolts…………………………54 ft-lbs
Intake manifold nuts……………………………….......17 ft-lbs
Exhaust manifol-to-cylinder head nuts………………..23 ft-lbs
Exhaust pipe-to-manifold nuts
D16Y5, D16Y7.……………………………....25 ft-lbs
D16Y8.…………………………….................40 ft-lbs
Exhaust manifold upper heat shield bolts…………….17 ft-lbs
Exhaust manilfold lower heat shield bolts
D16Y5, D16Y7.……………………………....96 in-lbs
Flywheel-to-crankshaft bolts………………………….87 ft-lbs
O2 sensor……………………………….......................33 ft-lbs
Oil pressure switch………………………………........156 in-lbs
Oil pan drain plug
D16Y5, D16Y8………………………….…....29 ft-lbs
D16Y7.……………………………..................33 ft-lbs
Oil pan-to-engine bolts………………………………...104 in-lbs
Oil pump pick-up tube to pump housing nuts………….96 in-lbs
Oil pump pick-up screen-to-main bearing cap………96 in-lbs
Oil pump housing-to-block bolts…………………….96 in-lbs
Oil pump cover-to-housing…………………………..60 in-lbs
Rear main oil seal housing bolts…………………….96 in-lbs
Timing belt cover bolts………………………………86 in-lbs
Timing belt tensioner bolt……………………………33 ft-lbs
Valve cover bolts………………………………..........86 in-lbs
VTEC lock-up solenoid bolts………………………104 in-lbs
Water pump bolts……………………………….......104 in-lbs
thanks! Ive also made a few changes, im now using arias pistons and eagle rods. I'm also switching to a y7 block, i got it for free, and i dont like the way the notches look that i did on the y8 block..i'm still going to be using the y8 head and y8 crank in the y7 block. eveything else however is going to stay the same.
Discussion Starter #20
well its the clearence that i have with the std 75mm bore. Ive read a couple builds with that ptw and theyre still running strong.
1 - 20 of 24 Posts
