Any tips would be helpful. 89 civic EF hatch, d16y8, almost all suspension mods are done. It's got 7,500$ plus In aftermarket parts going in. Fuel,air,Ecu, brain crower stage2 N/A Cam, Brian crower springs, Titanium retainers, ferrea valves,ferrea oil seals,370cc injectors,70mm skunk2 throttle body, rebuilt vtec solonoid, head studs,.30 cometic head gasket. Nippon 75.5 mm high compression pistons. King race bearings,milled head and block, block guard, 5speed with stage 2 clutch, aem afr, 3/14 catback with 4-2-1 header, walbro 255 fuel pump, an lines with regulator, msd blaster 2 coil set with cap rotor and wires, ngk race plugs, aluminum rad, new hoses and vacuum lines. Probably more to much to list. Need to know should I keep the stock rods with the pistons that are for the stock rods and go for 200hp or should I upgrade to h beam rods and forged. Is 200hp reasonable for the amount of upgrades I have? Also I want to port and polish the head as well as do the oil system mods.
All parts I have purchased for the build.
