1 - 10 of 10 Posts
honda civic
i looking to get 300hp out of my 99 d16y8.
can some one point me if the right direction
Vitara Turbo Pistons with NPR rings
H Beam Rods
ACL Rod Bearing
ARP CONNECTING ROD BOLTS
ARP HEAD STUD KIT
D16y8 Block Guard :3dtard:
lots of more parts to list just the start just looking to get an idea thanks.
I made almost 400whp on Vitara/FJD set-up on a Y8.
no block guard..
.50 Trim turbo @ 15psi.
only thing that stopped me from hitting 400 was my exhaust and shit..
one grumpy old man
i made 480 whp with a stock y8 head and cam.had valve springs tho.
If you guys could elaborate more on your setups up that'd be awesome. I actually plan on doing a similar build this winter.
honda civic
whats wrong with a block guard. and am i going to go by stock clearances. thanks for all the help
They call me Awesome!
^They're not needed, have the potential to reduce coolant flow, and it's easy to damage the block on installation if it's not done right and by a professional.
honda civic
ok thanks i will take your word for it. thanks for the help. and what about the clearances if i dont bore nothing out just hone the walls do i go buy the dealers clearances. if someone can answer that. that will help alot thanks again
1 - 10 of 10 Posts
