1 - 3 of 3 Posts
First time building a motor and was trying to get a full list put together of everything I will need so if anyone has some sort of full build list that would help a lot also help with any input or idea would be nice anyway here is what I got so far
Font Darkness Terrestrial plant Screenshot Monochrome photography
Bare block and crank only, or did it also include the mains/girdle?
If it legit was ONLY the crankshaft and bare block, keep in mind, you will likely need a line hone to true up the mains, whatever ones you get.
Depending on rods chosen, you will need to notch the lower skirt of the block.
1 - 3 of 3 Posts
