1 - 1 of 1 Posts
00 ex d16y8, every time i completely let off the gas at a lower rpm (1500-3000) the car bucks slowly and then does it again when i initially press the throttle.
also kind of hard to explain but the car hesitates a good bit at lower rpm driving around town, you feel it a lot when trying to go up hills. when you hit highway speeds its smooth though.
have a cel and 2 codes (p0131, p0141) both are for 02 sensors so cant see this being my problem
recently replaced the plugs, wires, cap, rotor, cleaned the injectors and put in a new fuel filter and its still hesitating.
if it was the tps wouldnt it throw a code?
been dealing with this for months someone please give me some insight. this person seemed to have the same problem but the fix was never put up.... http://www.d-series.org/forums/general-tech/190961-having-hesitation-acceleration-distributor-help-please.html
1 - 1 of 1 Posts
