1 - 9 of 9 Posts
I'm beginning to build a Y8 for boost and plan on making 350whp. I'm not trying to cheap out but not trying to break the bank either. Any ideas on a clutch? First round of cleaning started today, this weekend is complete teardown and measurement for bearings and rings begin.
Watching this build. Good luck to you
Meat Popsicle
91 CRX Si
Action stage 5 (2MS). Been super happy with my action 1MS and you can order from Chris (Aquafina) at WDR which is a site sponsor.
stay brand name for clutch. No offbrand, even if it says 1000whp support.
Port the oil pump. use devcron to rebuild partial corners/port shaping. Find a good picture guide!
Else should be quite easy to hit over 300whp for support. Typical pistons, rods, and do any and all required maintenance stuff (checking sensors, changing seals, etc...)
Discussion Starter · #7 ·
Thanks for the input. I went with the comp stage 2 racing disc. I ordered rods and now I'm at the piston option. I'm going with stock compression. Any ideas on a good upgraded piston that isn't press fit? Also I'm not doing the vitaras.
1 - 9 of 9 Posts
