Hey guys, got the block back, notched it and the girdle. Pistons and rods are in. Gapped the top ring to 0.019 and second 0.022 then oil rings to 0.025. Rods have clearance.
Also, from the P2P0 -Performance 2.0 website, the instructions say that if you don't have a stretch gauge, torque the ARP 2000's to 55 ft/lbs. I've looked this up and yes some others have said this, but damn that seems real tight. And yes I did apply the ARP high torque lube. Anyone else got something to say about this that differs?
I made a silly decision to buy a skunk 2 intake manifold and adjustable cam gear off of a guy today. However I am not 100% sure if they are clones or not, cam gear would be a tuner series before skunk moved to pro series. But I cannot find any pictures of the old ones. If you google "real or fake skunk2 cam gear" there is a thread where someone has the same gear in a different color but only one guy says its legit -I don't trust one reply.
As for the intake, team integra has a guide, but it is for a different manifold. From what I can see it looks the same from the one on skunk's website, and the inside does look correct compared to team integra's guide, but reassurance is good. If anyone has one, or knows the correct size of the throttle body port would you tell me the diameter?
At the end of the day, if they are clones, I will still use the intake, but definitely not the gear. It's on me for not doing more research if I got ripped of :frown:
