1 - 2 of 2 Posts
This is kind of a noob post an i don't mean it to be but I'm curious as to know how to time the set up listed above. I was told that you have to have a z6 cam pulley an crank pulley in order for it to be timed correctly, is this true? It's an obd2 block obd1 head an the head is stamPed po6
Y7's and Y8's use the same cam indexing, the same cam gear, and have the same deck height.
therefore all you do is follow the factory service manual for 96-00 cars... they should only have one timing method listed since they are the same
1 - 2 of 2 Posts
