1 - 11 of 11 Posts
finally close to getting my build done wanan see waht you guys think and have some questionssss!
d16y7 Notched
Exedy Lightweight Flywheel
Arp Flywheel Bolts
Exedy Stage 1 Clutch
Vitara 8.5:1 low compression pistons
Forged Eagle H-beam rods
Arp1000 Rod Cap Bolts
y7 stockhead
Aem Adj. Cam Gear
rc750cc injectors
aem adj. fuel regulator
walboro 255 fuel pump
Skunk2 pro series intake
Mini-Ram turbo manifold custom welded flange
Godspeed Gt3076r turbo
Front mount intercooler
Full 3" exhaust 4.5"outlet
2.5" downpipe
Hondata s300 p28 Boost package
Jumper harness
what oil restrictor should i use for that turbo??
i have a feed on it now and honestly dont even know what size it is it was from an old set up there a way to check the size? i have the turbo brand new and the line was already on car and need help with coolant fittings and locations to tap.
98 ek hatch
search also search turbo coolant lines. a guy on here has a great write up on where to run the lines with out tapping into other lines
any ideas if that restrictor will fit the turbo i have? its a godspeed gt3076r...godspeed doesnt even sell a restrictor for that
4dr eg
I remember on some forum back when it was figured out too much oil was getting in the turbos, some body had made theirs. There was a way of using a drill bit on a scale to figure out what you needed. What he did was weld the hole shut, drill with one bit, and use another by hand. I did it and it worked perfect. Just dont know what site it was on. Could have been todd...
is anyone running this turbo out herre?!?!if so can someone send me the link that will let me buy the RIGHT restrictor size for it? and also a oil/coolant feed and return kit would be awsome too. suprising like i said godspeed doesnt make a restrictor for that turbo and i dont wanna buy things that wont fit...please and thank you all for your help
98 Civic CX-T on E85
thats just a ching chong ebay turbo...its probably journal bearing so you shouldnt have to run an oil restrictor...but since it is ebay crap i would run it till it breaks and buy a nice turbo...
it is a journalbearing. and i wouldnt risk it by not useing a restrictor..im on a low budget till i start working again so it has to last for a bit
95 del sol turbo
It depends on the turbo. There are two diffrent fittings for the garrett gt series and the t3 turbo's. I dont want to give you the wrong information but typicially journal bearings take more oil then the GT series. So I would call the company that makes the turbo and ask what size restrictor they suggest and what size fitting is needed to go into the turbo. Or you can go to a hardware store and see which size fitting the turbo is.
Im pretty sure this works with the t3 turbo's has a 1/8 fitting to the turbo to -4an.
Xenocron Tuning: .063" Oil Restrictor #[oil restrict]
Here is a feed line so you can mount it to the back firewall to take some pressure off the block thread. It also has an add on for the t3 restricter I think. Size is 1/8 to the turbo
Xenocron Tuning: Remote Oil Pressure Tee Kit #[oil line kit]
I used this one for my bb turbo and had to get a -3an female fitting to -4an male fitting for it to work right. This has a 7/16 turbo side fitting.
DIF 10016 Turbo Oil Restrictor -3AN to 7/16-24 (.032" Oil Hole Size)
7/16 turbo side input to a -3an line with a .63 restrictor.
DIF 10017 Turbo Oil Restrictor -3AN to 7/16-24 (.062" Oil Hole Size)
1 - 11 of 11 Posts
