I have a 99 Honda civic DX 5 speed. Completely stock other than cold air intake. I plan on doing a budget build and installing a turbo on it. And I plan on spending at most 1200. I need a run down on exactly what I need as far as fuel supply, ecu, ECT.... I already have a fresh block with eagle rods and vitara pistons. I plan on running about 10lbs max. My next purchase will be a y8 intake. And other than what I need for the tuning what kinda of power figures will I most likely be looking at?
psi means dick
do a search
need more bank
do a search
psi means dick
do a search
need more bank
do a search
I wouldn't be asking if I had not already looked. All I need to know is what ecu and supporting modifications I need. Can I use a chipped p28 ecu with a jumper and use chrome for tuning. And the reason I listed my goal boost levels is due to me needing to know what cfm injectors along with a fuel pump and regulator I will need for the 10lbs. Am I leaving anything out ???
if you searched, you'd have your answer. next!
Discussion Starter · #5 ·
People like you are the reason it's hard to find answers because everyone has smart a** answers. If you have the knowledge then just help with my question. If you dont then you have no reason being on my post. Why waist your and my time with a stupid response when you could just answer or leave it alone. Do you have this knowledge or not??
I does. but you might need to do some reading lol. the true asshole in me wants to tell you to use spell check, but then again, Ill just leave this
ej8
This has been covered a billion times.
The question your asking show you havent search at all.
A simply search would of brought up alot of info. Then tbe questions you ask would have been very different.
There is even a stickey on this fourm that covers alot of this info
