O.P. states this swap is Automatic - to - Automatic.
-So, IACV units, for the 'Y7 and Automatic 'Y8, are the same, nothing to do there.
-Also, VTEC Solenoid is not the only wire. Knock sensor will need to be run as well (use a shielded cable).
-Lastly, I thought there was an Oil pressure switch @ the head too, for VTEC activation, but this might only be B-series engine, can't remember.
To the O.P.: If you can get the complete engine harness, with the 'Y8 swap, you are ahead of the game. It will save you from having to run the VTEC wires.
