1 - 7 of 7 Posts
I recently swapped a D16Y8 in my 1997 Honda DX that originally had a D16Y7 in it and I have two lines that I can't figure out
Pictures here ^
One is a coolant line that is supposed to go to the top (or maybe bottom)? of the IACV. One is coming from by the thermostat and I think the other originally came from the back of the block but I don't see a nipple on the back of the Y8. Maybe it's there and I can't see it but I removed the fuel rail and still don't see one.
The other one is underneath the intake manifold next to where the PCV hose leads. I can't figure out where this one goes either?
Please help me!
Thank you!
One line goes from the thermostat to the iacv. The other side of the iacv goes to the back of the block. There's a larger pipe there that cool at flows through. It has a nipple sticking out of it.
I'm having a hard time seeing it, I think I'm going to pull the whole intake and take a look. Any idea on the vacuum hose? I've looked all over the place and I can't see where it would possiblly connect to. Maybe when I have the manifold off I'll see it.
use a y8 intake
D16Y7
D16Y8 (Manual)
D16Y8 (AUTO)
Reactions: slo_eg8
1 - 7 of 7 Posts
