1 - 4 of 4 Posts
97 civic, 95 jeep zj
Just picked up a 97 civic with a d16y7, car runs pretty good. The other night i got on it, hit 5500rpm an the rev limiter kicked in?? Car does have a cel on, codes are for a ect sensor, a o2 sensor,a fuel tank pressure sensor an the weirdest is for a vtec silinoid which i dont got vtec... so i checked the intake an got P2K-1Pt-5 which would be a Y8 intake right?? pcm# 37820-P2P-A32.... 921-209140 which is wrong correct?
You have a VTEC ECU, the P2P is for the Y8 VTEC motor. You are about 1000-1500 RPM short on the fuel cut for that motor. But that could be a bad tach, I don't know.
1 - 4 of 4 Posts
