1 - 4 of 4 Posts
D
Hello i just got a free y7 motor, am going to build it for some heafty boost. My only question is the only motor work ive done is on a6's. The y7 would be going in a 90 hacht SI. So my q's are how easy would the swap be. If am thinking right the y7 is obd1 so there would be a few things i have to do wiring wise coorect. I just want to see how much wiring i would have to do. Thank you
96-98 y7's are obd2
99-00 y7's are obd2.5
D
so would it be a hard swap to put in the y7/y8 mini me into the 90 SI hacth. I also have a a6 block no crank/pistons. Would it be easier to take y7 internals into a6 thanks
1 - 4 of 4 Posts
