1 - 3 of 3 Posts
I just bought a 99 dx civic with this problem. Check engine light is blinking
I did a compression test on all cylinders and I get 175 on cylinder 1-3 then cylinder #4 is around 30 so i changed the piston rings with it I also changed my distributor, sparkplug, plug wires, head gasket, timing belt, water pump, headers (oem), fuel filter and injectors (oem). I also did a valve lash on factory setting and did my timing right.
After all that work the car still mis fires on cylinder #4!
What else do i need to do???
Btw i used the helms manual to do all of this....
1 - 3 of 3 Posts
