1 - 2 of 2 Posts
EK hatch
Hello and thank you for taking time reading this. Second gear in the above stated transmission will sometimes pop out, i think it's because i have recentley installed the Skunk2 shortshifter,problem 1. Second problem is under heavy acceleration around 3300rpm and 4100rpm it almost feels to me that the car is losing power in what i can only describe as a slipping feeling...? I hope this makes since to whomever can answer me, thank you again for reading and all answers will be greatly appreciated. Thanks, Sheasekhatch
*Edit A/C is not running under these conditions, could it be from the A/C compressor cycling on/off? As mentioned it's only in second gear under moderate to heavy acceleration.Thanks, Sheasekhatch
EK hatch
okay, found the second gear was only from short shifter and partial operater error as fas as popping in and out. Now this was weird i watched my rpm's in second while i floored it, the rpm's hit 4000 and acctually dropped to about 3600 then started building again, all while i had the pedel pinned to the floor. anyone?
1 - 2 of 2 Posts
