which timeing belt do i get for a d16y7 bottom with JDm d15b head z6 belt ?
thats what i said, get the belt for the block/tensioner/waterpump, the cam gear is the same diameter so that would not change the belt, only the parts on the block would change the belt."i've always been told to go with the block, because that is what changes the length of the belt(block height). most of the heads are the same dimensionally, it is the block height and water pump pulley size that changes everything. i would say go with the one for whichever block you plan on using."
