1 - 6 of 6 Posts
T
I've got D16Y7.
my low block was broken.
I found D16Z6 low block.
will it work if I put D16Y7 on D16Z6 block ?
yeah but you might as well spend a little extra on a mini-me setup too, but I'm also wondering if the compression will be low?
T
did anyone do this mini-me swap ? D16Y7 HEAD on D16Z6 block ?
what problem will be with compression ?
I undestand that also I need to change output manifold.
T
more:
these engines have differences
1) compression (D16Y7 = 9.4:1, D16Z2 = 9.2:1).
2) piston set
3) ring set.
will be any problems as a result of these differences ?
C
the same compression ratio as a stock z6 since the z6 and y7 has the same c.c. volume.
1 - 6 of 6 Posts
