1 - 20 of 22 Posts
formerly Kit88
ek hatch
Is this small turbo good for a stock d16y7 engine???
Does the automatic tranny can hold this power or is gonna blow very fast ???
Should be fun a comfortable automatic DD with a little more power.
yeah, the t25 is small enough that i dont think it should make enough power for your tranny to be the issue, most ive seen pushed on them is ~200whp ish.
the transmission will be ok unless it is BEAT on.
formerly Kit88
ek hatch
Great!!! I´m think I´ll try, an in case my auto tranny blow up, I´ll do a std swap.
formerly Kit88
ek hatch
Get a decent size transmission fluid cooler, and it'll last forever... or at lest untill the clutch disc thingies wear out.
Good point..
formerly Kit88
ek hatch
I threw 10psi at a auto y7 with 100k on it and a greddy 19t and the tranny held up fine and is still in my garage waiting to be sold cause i swapped in a y8 5sp.
Do you was using an oil cooler on your tranny, or any spercial care on it???
Well?
torturedsol ran a TD05 with like 7psi and blew his auto up. fucked OD right out of it
oil cooler, 15k fluid changes, don't go beating on it.
I just want the torque!
WOT shifts = death to Honda Automatics, so does manually holding it into gear like D2.
Acura TL-P
I also used to own an auto Y7 with a 15G on it. After turboing it I kept it probably 6k miles, the 2nd owner put about 40k miles on it and the now 3rd owner still runs the stock tranny at well over 100k on it.
Just for the record, I boosted my daily driver 95 D16Z6 (75000, engine rebuilt 10k ago) with a GT25 @ 9psi, sugarcane ethanol (Brazil ;) and added a small tranny cooler. I've run 2k miles so far and its fine. GT25 fitted perfect to me cause it only spools when I ask for. A smaller turbo should be worse to the torque converter when slipping mainly as a daily driver.
Travelling also got way better now, no more uphills :)
i had a t25 running 8 psi on my d16 auto...all i did was put an oil cooler and it worked fine...was a dd for about a year...only reason i took it out was to go 5 speed.
1 - 20 of 22 Posts
