PLEASE READ THE ENTIRE POST TO HAVE A FULL IDEA OF WHAT IS GOING ON HERE
heres my setup first of all that i just purchased a week or so ago
its a 95 hatchback with a d16y5 swapped into it using a obd1 to obd2a harness for the p2n ecu
issues
im trippping the following codes
22 vtec oil pressure switch
41 primary 02 sensor
54 ckf sensor
63 02 sensor heated
65 02 sensor heater
the car has a very rough idle and has heavy smoke coming from the valve cover
i have replaced the valve cover gasket / spark plug gromets / plug wires / plugs / intake filter / PCV valve
* since the motor is obd2a do i need to do some kind of special wiring for those sensors?
* do i even have these sensors or do i need to do the bypass wiring for them?
* the oil pressure switch is connected into the ecu clip but doesnt seem stable can you wire it directly into the conversion harness?
ANY IDEAS ARE APPRECIATED!
issues
54 ckf sensor
63 02 sensor heated
65 02 sensor heater
