D16Y5 Civic "electric like" noise when under load.
802 Views 8 Replies 3 Participants Last post by  Georgia Eg
Hello everyone! I have this problem on a D16Y5 Civic. When you accelerate in while under load (on a hill or something), it starts making a weird noise like an spark or electric noise, it sounds around 20% of the pedal travel and increases intensity with it. Other symptoms that I was able to diagnose are power loss and consequently overheating, clearly when the noise is happening. Checked distributor and the only interesting thing that I found was that it has a bit of oil into it, I do not really now if it could be related, replaced the air filter because the old one was very dirty and also checked ignition timing and it was a little off, I fixed it but the problem is still there (Now it is just a little lower). Any ideas on what the problem is?
Note: It only happens when the engine is under load, if you accelerate in flat it does not make the noise until you are almost full on the gas.
Also, I managed to record the audio. Sorry for all the wind, but I think you will be able to hear it.
All help is truly appreciated
Audio
1 - 9 of 9 Posts
Like a whiny noise, ie electric motor, or popping noise like an electrical arc?
I would say like a popping noise. I managed to record this audio
It is very similar to this one too:
I think you are right. After researching more I guess it is detonation related, and from all the possibilities, this one fits better (I will also try higher octane fuel, but I do not think this could completely fix it).
Where should I start with lean mixture?
I am not a professional at all, car was given to me to go to college but I can tell maintenance has not been good. So I am trying to learn things and do it myself :). Of course, with a lot of research and patience in the process to not make anything explode.
Well, as for now, I can assure that fuel filter looks very old, probably injectors are dirty too. Btw, no check engine light at all.
I do not want to replace or buy something that won't help at all. I appreciate the support.
I can't hear anything in either of those audio clips, but if it's pinging check your timing. You can also try running a high octane fuel and see if that affects the noise. My daily used to ping if i had a car full of people with the AC on and go up a hill ONLY if i had low octane fuel in it. I'd put in high octane it would be smooth in all scenarios.
I'd verify fuel pressure, pull out injectors and make sure they're not gummed up around the nozzle, throw a new fuel filter on it, if you wanna get into it you could install a wideband and see the AFR in real time, that would at least verify if you're running lean, but it's a bit of $$ for that.
Threw in a new fuel filter, tried higher octane fuel and used some injector cleaning additive and no more pinging noise for me :) I guess the filter that it had was the original one haha (The damn bolt was extremely hard to loose and fuel had a huge amount of dirt), better watch out those old parts. Thanks guys!
Reactions: 2
1 - 9 of 9 Posts
