1 - 17 of 17 Posts
I need few sugestions if possible..
I have sell my d16z6 hi copm, and now i will build turbo d16y2.
I have:
Vitara pistons 75mm
Eagle rods
Arp studs
Cometic head gasket
Ebay iron manifold
Ebay turbo Ar63/ar50 t4
Tial 38mm external westgate
I will use standard d16z6 intake manifold, and p28ecu..
Can you give me few hint what to do, how much power i can expect, will it be big turbo lag, because i am not so good in D series like in K series..
Thanks
I'd put all that in the Z6
Stage-III Turbo
Oil Cooled Only!
Standard T3 4 Bolt Inlet Flange, Designed to fit most Aftermarket Mainfolds and OEM T3 Manifolds.
5psi to 20 Psi Peak Power Performance Output Capability
Designed with a Standard 5 bolt T3 Flange
Includes internal wastegate port (optional for use)
Compressor Specs :
3" Compressor Inlet
2.130" Inducer
2.755" Major
T04B/T4 Type Compressor Housing
2" Compressor Outlet
Compressor .49 A.R.
Compressor .50 Trim
8 Blade Type T4 Compressor Wheel
Turbine Specs :
T3 Type Turbine flange
T3 5 bolt flange
Turbine .63 A.R.
2.205" Minor and 2.570" Major Propellar
T3 Turbine Housing
2.274" Outlet
12 Blade Type Turbine
Can modified to use external or internal wastegate.
Suggested for 1.6L to 2.3L engine up to 150-400HP
I tihink that is description of turbocharger.
I want about 250-260hp (that is yours 215-220WHP)
Very possible it has smaller Ar so the turbo will spool faster and with 50trim housing it wouldn't be hard.
I see now that in upper description writes 8 Blade Type T4 Compressor Wheel, i look on turbo and it have 12 on intake and exhaust..
Does it matter??
Does it matter??
It should be fine don't worry about 12 blades and such. Be more specific and when you say t4 does that actually mean a t4 flange? Or t3-t4? Look into how much cfm does the turbo produce. Like for example an ebay Ching chong t3 t4 turbo that is being advertised as .50 .63ar isn't really a 50trim, but more like a .48trim. Ever wonder why they never put info on how much does it really flow? A turbobetics 50trim .63 flows about 50lbs and Garrett 57trim .63 flows about 56lbs. I have used an ebay 50trim Emusa brand turbo and made about 300whp on pump @18psi. Obviously aren't the best turbos out there so don't expect it to last for to long, but with a healthy built block and the right tuner you will reach your goal very easily. You can difenitely go fast with these ching chongs I've run 11s with it. Post a link of that turbo you're buying
thanks man..
I have all in my car service garage, i can photo it tomorow, and put pics here, to see what i have..
I didnt buy it to build something, from time some parts left and now i have almost everthing to build motor..
I will go on acr bearings main and rod, victor reinz gaskets (cometic head gasket)..
Where can i buy base map for turbo, to start motor..
What's you location? Base map is something your tuner needs to provide you, or who's going to tune your car?
Hi, and why didnt you asked this on your local forum? You have 2 options about tuning, you have Tunerc in Slovenia, and guy whos nick is Bruce lee from Slavonski brod or somewhere near that place. Tunerc works on ectune and dyno and he is a pro, and slaven works on crome and he street tunes most turbo hondas on sr.
So build the engine ask them for a basemap and tune it.
I know for Slaven, last month he prepaired my p28 for chip..
I will ask him..
Thanks for advise..
HI again..
I dont wana open new thred, i will ask here..
What is best camshaft for d16turbo get/price.. or what is best oem camshaft for turbo..
How much is different with and without camshaft for turbo..
Thanks again..
I got new ARP studs and Vitara STD pistons and few more things for 100euro..
I have good block with no sign of wear so it is good deal :)
This is cheap build, i have only buy forged beams and exhaust manifold..
1 - 17 of 17 Posts
