1 - 12 of 12 Posts
As I've read some of the guys here finish the 1/4 mile in 15 sec's with their D15B and few simple mods like h/i/e
While I hit 16 sec's with My D16y8 with the same mods
anyway this doesnt matter now, what i would like to know is
I have a D16y8 and now I have a D15B engine.
Is there anything i can do to replace some parts from the D16 into the D15 to gain more power?
for example, TB and so on.
the throttle body's will be the same. Everything but Desplacement,rod leignth ect. The d16y8 is just an USDM version og the JDM D15B. I ran a 15.9 with my d15b with: Megan Racing header, 3 in exhaust, MSD coil, intake, lighten flywheel.
by the way i'm running the D16y ECU which is p2p obd2
would it make any difference in power if I use the D15B's Ecu which is P28 as I guess, or it wont !?
1995 Civic EX Coupe
the only way you can run that P28 is by getting the OBD2-> OBD1 conversion harness.
Man i run 15.2 with my SOHC ZC Vtec (JDM D16Z6) The biggest advantage to buying a D15B is, normally lower mileage and better compression numbers then say trying to find a low mileage D16Z6 in the US (one lower then 70k) Other then that 1.6 > 1.5
Discussion Starter · #7 ·
This is the only way to engage the vtec?
or it will kick in anyway and i'll be able to hear it?
p-08 is the ecu that mates with jdm d15b
What if I didnt run the P08 Ecu and kept using the current one which i have?
Thnx for the input
ugh.... the weight of your car is gonna be by far the largest variable when comparing too nearly identical motors.... a d15b in an HF crx is obviously gonna be faster than a 4 door civic with a d16y8....
i wish i had a y8 in my 4dr, soon my pretty, very soon
Yeah if you have an '96-'00 coupe figure just over 2700 lb with driver, sedan it's close to 2800 lb.
Previous generations were a lot lighter, which is why CRXs could get away with high 15s making a whopping 108 hp at the crank. Meanwhile us EK owners are stuck in low 17s/ high 16s with near 130 hp because we gotta haul our heavy butts down that long stretch of track...
1 - 12 of 12 Posts
