ok well i got a 93 civic cx with a d15b8 block and buddy of mine said this block has a D16z6 head on it were could i check if this info is correct?
91 CRX Si
Well, first thing that would tip it off would be the Vtec solenoid on the back of the head on the Distributor side. Also, A Z6 head will have the spark plug holes towards the front of the valve cover, A B8's will be towards the back.
Only one way to tell is to look at the head. It should say p08 somewhere along the exhaust manifold with the year the head was made. Looks vtec head alright.
yup says po 8 on it thanks, what block should I use for this head since I might go for 200 thru 250+ hp on turbo
FAMILY MEMBER #316
use a y8...spun bearings are fuckin awesome
