1 - 4 of 4 Posts
Toyota AE82
Hi members.
Just sharing some experience I had with the "broken" A9 I replaced the other day.
The old engine
Ready to drop the old engine
Dropped it on a steel plate and slide it out.
Where I got the new engine, this is about 10% of the engines that this place has
New engine on the crane
Surprised by how clean the import engine is!
Engine installed
The only problems I had was the the import engine injectors were stuck so I swapped over the old ones.
And the rev counter did not work with the ZC distributor so I also swapped it.
Everything else was 100% straight swap
You can do the engine swap at home no problem. As you saw you can remove the engine without removing the gearbox by removing the head and few other stuff and dropping the engine to the ground. The sub assembly is not heavy so you can do it on your own.
Toyota AE82
Thanks Beaver :)
No I am not on myhonda. I am only on this forum because I like Honda :p I am on 9000rpm and TwincamClub and here :D Link
I work on any random car but when I work on a Honda this forum can be of great help!
Got the engine from Engine den
1 - 4 of 4 Posts
