1 - 12 of 12 Posts
Hi Everybody from Argentina
I have a Civic EH9 D16A9.. I know so that there is a millon topics about SOHC Headers that no fit without modify in the DOHC head.
So my question is... Anyone tried B16A2 ( VTi ) header? will this fit pug and play?
I know is a B series Header but is also a DOHC Head 1.6L.
My question cause in Argentina we don´t have a lot a of people who can take the job of modify a new header they just want to sell you his own header ( bad quality ) or the one´s I Know who works excellent with the best quality will cost around u$d 720
So my idea is to import a Header and make the rest of the exhaust here in stainless metal around 2.25"
If anyone can suggest me a better idea im open to hear it.
Ok.. I will try a DC Sport 4-2-1 i think.... DC add D16A9 in aplications but a lot people here say that is no the same bolt set up as D16z6...
Honda Civic 1987-1991 3-door hatchback 1.5i GL/GLX (D15B1 - ED6)
Honda Civic 1987-1991 3-door hatchback 1.6i DOHC (D16A9/ZC - ED7)
Honda Civic 1987-1991 4-door sedan 1.5i (D15B1 - ED3)
Honda Civic 1987-1991 4-door sedan 1.6i (D16A6/A9 - ED4)
Honda Civic 1991-1996 4-door sedan 1.5 DXi (D15B2 - EG8)
Honda Civic 1991-1996 4-door sedan 1.5 LSi (D15B2 - EG8)
Honda Civic 1991-1996 4-door sedan 1.5 VEi (D15Z1 - EG8)
Honda Civic 1991-1996 4-door sedan 1.6 ESi (D16Z6 - EH9)
Honda Civic 1991-1996 3-door hatchback 1.5 DXi (D15B2 - EG4)
Honda Civic 1991-1996 3-door hatchback 1.5 LSi (D15B2 - EG4)
Honda Civic 1991-1996 3-door hatchback 1.5 VEi (D15Z1 - EG4)
Honda Civic 1991-1996 3-door hatchback 1.6 ESi (D16Z6 - EG5)
Honda Civic 1995-1997 5-door hatchback 1.5i VTEC-E (D15Z3 - MA9)
Honda Civic 1995-1997 5-door hatchback 1.6i LS (D16Y3 - MB1)
Honda Civic 1995-1997 5-door hatchback 1.6i SR VTEC (D16Y8 - MB1)
Honda Civic 1997-2001 5-door hatchback 1.5i VTEC-E (D15Z8 - MB3)
Honda Civic 1997-2001 5-door hatchback 1.6i LS (D16B2/W3 - MB4)
Honda Civic 1998-2001 5-door aerodeck 1.5i VTEC-E (D15Z8 - MB9)
Honda Civic 1998-2001 5-door aerodeck 1.6i LS (D16B2/W3 - MC1)
Honda Civic 1992-1996 2-door coupe 1.5 DXi (D15B7 - EJ2)
Honda Civic 1992-1996 2-door coupe 1.5 LSi (D15B7 - EJ2)
Honda Civic 1992-1996 2-door coupe 1.6 ESi (D16Z9 - EJ1)
Honda Civic 1996-2001 2-door coupe 1.6i LS (D16Y7 - EJ6)
Honda Civic 1987-1993 5-door Shuttle 1.5i GL (D15B1)
Honda Civic 1987-1993 5-door Shuttle 1.6i 4WD (D16A6/Z2)
Honda CRX 1987-1993 1.6i DOHC (D16A9/Z5 - ED9)
Honda Del Sol 1992-1998 2-door coupe 1.6 ESi (D16Z6/Y8 - EH6)
Thank that help me a lot, one imagen say more than a 1000 words.... you clarify me all the situation... I speak english but sometimes when it´is very technical cost me a little to understand.
\/Your Mom Was Here\/
Vibe GT
The best thing to do is put the gasket up the the head and cut the gasket out around the ports, then take the gasket and place it on the header like the picture and trace it with a sharpie so you know where to grind.
B-series Destroyer
4g 4d civic
I used a DC header and ground down the manifold to match it. I did nothing to the head. took me about 20 minutes.
B-series header will not fit. Port spacing is different.
What people do, is cut the header flange off, and then weld a D series flange onto the pipes. It works and I've seen some 11 second NA D series with setups like that. Pancho?
89 EF 4wd sedan
I used a B series header, cut the flange off and welded a DOHC ZC header flange on. The port spacing isn't equal on the B series, so the tubes needed to be pulled into alignment before welding.
1 - 12 of 12 Posts
