1 - 10 of 10 Posts
formerly Kit88
ek hatch
Who want´s to share with me a d16a6 w/p29´s base map ????
I´m also running i/h/e mild ported head a mild cam (don´t know the brand)
93 Legend L Coupe.
Make your own and smooth out the last column on the right's fuel tables, as they are wonky. Also, lean out the top fuel rows on the right, too.
Also, for the record, the DOHC timing tables are a decent place to start, but, you really should play around with them to figure out if the engine wants or needs that much timing.
formerly Kit88
ek hatch
Forget it, too late.
formerly Kit88
ek hatch
also crank main journals damaged.
1 - 10 of 10 Posts
