Why is there a difference?
if the deck height of all the blocks are the same... I assume there is a difference because of the PM3 head.
correct or wrong?
A6 TB 107 teeth
Z6/Y8 TB 104 teeth
good ol noob question to humble thysef. lol
a6 tensioner has more throw, the WP gear has more teeth and the cam center line is further out?
what i am trying to figure out is if there is an easy way to determine what timing belt to use.
for instance, with a y7 head on an a6. i would assume you would need something just slightly shorter than a 107 tooth belt. perhaps a 106? or can the tensioner account for that?
99% sure a d15b2 tb is 106 teeth.
VX is 103 teeth
thanks bone.
formerly Kit88
ek hatch
If you want Danz, I can check the part number on my timing belt, but I´m running and a6 block with a z6 head, I don´t know if this will work for you
Btw, it is pretty hard to put the timing belt on.
sure kit, do it up. the more info the better.
i checked the tensioner OD's. (though i am not sure how interchangeable these are, the Z/Y series have a longer arm sticking out)
B2/B7/A6 tensioner OD is approx 56mm
Z1/Z6/Y7/Y8 tensioner OD is approx 52.5mm
checked out some water pumps too. although the OD measurements aren't 100% because i only had a clear ruler to use....
Z1/Z6 water pump is 19 teeth approx 55mm OD
B2/A6 water pump is 19 teeth approx 54mm OD
Y7/Y8 water pump is 19 teeth approx 56mm OD (has funny appendage making the WP cog longer)
if anyone has height/offset differences between the head castings that would be super.
does anyone know if there is a 105 round tooth x 24mm timing belt floating around?
