1 - 13 of 13 Posts
ive been searching around and cant find any good info on swapping an a6 into an EG chassis, the a6 will be a high comp mildly built
i wanted to know if its basically bolt in for EG chassis
or do i need mounts etc...
wheres my money man!!
youll need to put the eg drivers side mount on the a6, the eg tranny will bolt to the a6, use the eg intake manifold or someother one like the y8. so all in all only need to change the drivers ef mount to the eg and use the eg dizzy
OMG TOTALLY COOL TITLE!!!!
easiest way is to change just engine block and head and keep everything else from the eg. on the motor like said already you need the drive side motor bracket or the mounts wont fit in.
just wanted to be sure
do you mean the EG motor mount (RED)
will fit but the engine mount bracket (GREEN)
will have to be from an ED???
pic just used as an example
hmm ijust wanted to know exactly which mount/bracket si-hatch86 and sleepingciv
was talking about
so theres NO way to make it sit completely straight?
n/m eg motor mount and motor mount bracket
sorry for some reason i wasnt understanding
the beaves always got my back!
epic win
1 - 13 of 13 Posts
