1 - 7 of 7 Posts
1992 Civic CX HB
what are the differences between the a6 and b7 heads? i read somewhere that the cams are interchangeable?
will a b7 distributor bolt on an a6 head?
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
Exact same casting. Difference is the cam and springs.
a lil more in depth
The Heads
The B7 and A6 head are the same casting. The difference between them are the cam and springs. However, Honda ran out of B7 springs in Mid ’93 and had to dig into the A6 surplus. So if you have a mid ’93 and beyond B7 head, you’re already running A6 springs anyway. If you want higher revs (above 7000) with an older B7 head, it’s advised that you upgrade your springs and retainers.
This info has been covered numerous times. Difference is in the cam. Yes cam swap, yes dizzys swap. I have done it a few times and it gives a slight drop in my lap times but I would just send it in for a regrind if your looking for any noticeable power
1992 Civic CX HB
thanks guys. i've got a block sitting in the garage i'm going to build.. but needing a head.. wasnt sure if i could use an a6 head or not.
racejunkie, i understand about searching.. sometimes people like me who are way too busy to spend searching through info to find what i needed. I really do appreciate the info though.
Honda?
Not trying to hate, but on like the first or second page is Nasty Canasta's amazing write up on this exact thing.
I guess I'm too busy to help on my findings from over a decade ago, like 1998 or so.
:exnbpslap:
1 - 7 of 7 Posts
