1 - 7 of 7 Posts
Hello, im building d16a6 mini me right now. Engine is already assembled but i have some problems with timing belt. D16Z6 belt is very tight and z6 tensioner dont fit on A6 block... for now i have d16a6 tensioner
My question is which timing belt, tensioner and water pump i should use for this mini me?
I found a lot of D16A6 blocks with Z6 heads but can't find any info about timing belts for this engine.
Ok, so no one respond me...
What I try so far:
I'm pretty sure water pump doesn't matter, every D16 have 19 teeths.
Z6 (104 teeth) timing belt is really tooooo tight, maybe it's because I use A6 tensioner which is bigger then Z6 one. But Z6 tensioner don't fit on A6 block because of different mounting points
Any hints or ideas?
Sloppy Jalopy
What I try so far:
Any hints or ideas?
what is "tooooo tight" ..
longer belt
thinner head gasket
shave head/block
use z b or y block
custom tensioner
find a used z6 belt
somethings gotta work....
93 maybe 94 coupe
Dso faq for d15 z6 mini me says the b7 belt has 2 more teeth than z6, if that means its longer and you have a tensioner that can tighten it up a bit extra try that. Theyre like 15 bucks.
Also look through catalogs because belts arent exactly app specific. I was hanging out at a shop that was telling a customer itd be 6 weeks to get a serpentine belt for their r34, I was like you guys cant be serious.
Went to google, found the belt SIZE needed for an r34 and googled that belt style and size, found a land rover belt that was in stock across the street at autozone, dude was up and running for 1/4 the price w no shipping cost or delay.
Shop owner gave me a spare transmission for helping out and scolded the dumbass he had on payroll for not being able to figger that one out. It was a garbage transmission from a swap to them, but still.
longer belt
thinner head gasket
shave head/block
use z b or y block
custom tensioner
find a used z6 belt
Too tight = as tight as guitar string, tensioner was turning red hot when engine was runing...
Finally after trying different setups I modify stock Z6 tensioner and now it's all good. I use D16Z6 timing belt.
Meat Popsicle
91 CRX Si
Surprised that nobody has responded since this seems like it would be a common mini me setup.
From what I’m reading:
“Use the z6 or y8 headgasket ,z6 timing belt and a6 timing belt tensioner and water pump.”
A6 tensioner is bigger than Z6 (56mm vs 52.5mm) so i think it's impossible to use it since Z6 is already tight fit.
I think water pumps also doesn't matter since all d series water pumps are the same? 19 teeths
Anyway thanks for response :)
Now I'm breaking in this engine, gonna tune it maybe this month
1 - 7 of 7 Posts
