Well i was checking around summit after ordering an edelbrock header for dirt cheap and I saw they had the arias pistons for a D16a6 on clearance for $291.50 so i did some researching and and calculation. So I wanted to know if my calculations were corrected the those pistons will yield a 11.9:1 CR on a D16y8 with a y8 2 layer headgasket.
The summit part number is ARA-3330000-NR
and the specs for that pistons from Arias Website are:
Dome Top
Bore: 75.05
Compression Height: 1.166
Dome cc: -0.3
Estimated CR on a stock D16a6 Head: 10.5:1
Gram Weight: 242
Dome Top
Bore: 75.05
Dome cc: -0.3
Gram Weight: 242
