1 - 6 of 6 Posts
As the title stats, can anyone confirm if the a6 fuel pressure regulator will work on a z6 rail? Looks like it bolts up the exact same, but i cant tell from pics if there is any different or if the holes are the same distance apart.
Reason i'm asking...On my Golden Eagle intake, using the z6 rail, the FPR aims straight at the intake runner barely giving me any room to attach the hose. If you look at the a6 FPR it does a 90 degree turn coming out of the regulator. Heres a pic reference of the 2 i'm talking about
Ef return line diameter is different, just a little bigger. This is what I have seen.
If the bolt and fuel hole config lines up the same it should work for you.
1 - 6 of 6 Posts
