89-05 SOHC flywheels are the same, some are lighter then others thats all.
Psst, wrong answer :)
90-00 share the same dimensions except for weight. 01-05 I don't know about.
88 and 89 use the smaller pressure plate bolt circle.
My bad I forgot 89 still had the smaller pressure plate, and yes 01-05 are the same 109 teeth, Disc outside diameter 8 3/8", spline inside diameter 7/8", spline count 20. 01-05 flywheels are 20lbs thou :(
cruising gas mileage FTW
What would be the flywheel weight difference from a 91 CRX Si and a 00 Civic Ex?
look it up on here or google.
d16a6 flywheel (90-91 civic/crx si)
d16y8 flywheel (96-00 civic // 96-97 delsol si)
88-00 are usually 18lbs(Vx was 15lbs so was some Cx's) 01-05 are 20lbs
