1 - 9 of 9 Posts
Hello,
this is my first post in this forum and my english is not the best (=
I'm from Austria in Europe and i'm searching for rebuild parts for my D16A8.
The D16A8 was found in the European CR-X from 1989-1991 (also know as CR-X ED9)
So can anybody tell me if this rebuild kit fits the D16A8 DOHC?
And if not please tell me what parts of this kit does not fit?
Or is there an other kit like this on Ebay that fits the D16A8 DOHC?
86 89 Acura Integra D16A1 1 6L DOHC Engine Kit HEKD16D | eBay
Regards,
Flo
:rockon:
93 Legend L Coupe.
Yes, that will work just fine. If you are rebuilding the engine just as a stock rebuild, I would still seriously recommend you also pick up a set of NPR P29-style pistons. They are far superior to the stock pistons. You will get more power and they are designed better to prevent some of the more outstanding flaws of the stock pistons. They are also very reasonably priced.
Ok sounds good :clap:
So everything from the D16A1 kit should fit the D16A8 except the Timing Belt?
Are the D16A1 gaskets the same as the D16A8 gaskets?
@ jlicrx
Why should the timing belt from the Prelude B20A5/B21A1 fit the D16A8?
Do they have the same numbers of teeths?
hello everybody , i have a question ..... i have d16a9 engine on ef and searching for an moded ECU and suitable turbo so which one i should pick ??? ,,,,,, yaah one more thing is the clutch which one . should i search for everything of the 88-89 integra ?? ... thanks
turbos and clutches are basically ame as 88-91 Civic/CRX
1 - 9 of 9 Posts
