i just ordered a pair of Bisimoto D16A1 Dohc cams for my 89 integra RS.
i was wondering if anyone could tell me what degrees they use so it could save me some time on fiddling with the adjustment. i have stock camshafts, springs, and valves.
Never finishes (TWSS)
91 Civic SI hb
you need to do that your self. and if you want to be lazy just put the both to 0 on the cam gears
1991 Honda CRX
Which Bisi cams? 1.2, 2, 2.4, etc.... Set the cam gears at 0 and 0 and go from there or as stated above degree them to get it perfect before you even start it up. There is a thread on degeeing cams on here, which is easier to understand than the honda tuning one above.
91 Civic SI hb
holy shit i feel stupid as hell. i didnt catch the typo until now. i meant cam GEARS not the camshafts :p
right, set both cam gears to 0(your still going to need to degree them to make more power. but your motor will start and drive). or if your not going to degree your cams you mite as well just use your stock cam gears.
