1 - 20 of 22 Posts
Hey guys, i have a 1998 JDM EK3 civic....the car has a D16A SOHC NON VTEC motor...i turbocharged the engine...i am usuing a t25 turbo with a 12:1 FMU and a msd btm, i'm running 8 psi boost..ohh the car has a auto transmission...i wana upgrade to a chipped obd 1 ecu but i need to find out what i'll need to do this....i'm thinking it's just the ecu and the harness converter?...is there anything else i need??..ohh does anyone know of a turbo cam for this engine?..thanks
so u have an ef si engine in an ek? not to be an ass but y? im just curiouse.
nah guys its a 1998 jdm civic....all the engine code has is D16A nothing after the A
formerly Kit88
I´m not an expert, but I know that d16a engine just comes on 88-91 crx si or civic si and it is obd-0.
and 98 ek´s are obd-II and come with d16y7 and d16y8 engines
You should check first if you car has this swap.
The car is from japan,right hand drive and its a obd2 D16A SOHC NON VTEC and thas the engine that came with the car
http://www.honda-tech.com/zerothread?id=1466506
there are more then just the y7 and y8 in the obd2 cars
op:
sorry i don't know of any strait up after market cam, but you could always have a custom regrind made. and yes you will have to convert to obd1 with a conversion harness. if you have a 3 wire iacv, then you will have to convert that also. and last a chipped ecu. gl with your build/mods
Thanks guys,would i also have to change the distributor to an obd1 distributor?? someone told me so..i jus wana make sure....by the way whats a 3 wire iacv??
Discussion Starter #16
Thanks again 99EJ6T....but what exactly is the 3 wire iacv?? and what will i have to convert it to...i didnt see anything on the link you gave me with "iacv"
Random Hero
You'd have better luck in the engine management section with this question. I thought I remember reading that auto ecus can't be chipped (and remain auto). But you could look into it more. I think pgmfi.org is down at the moment? That would have the info. Check this out also.
some bloke from h-t said:
You need an auto-auto conversion harness----> http://rywire.com/store/automa...5ce69
Then you will need to get an OBD1 auto P75 LS ecu and TCM for the setup. The TCM has to control the tranny.
it was on the second page.
iacv- idel air control valve
and here is some info for you as far as the conversion:
http://hondaswap.com/reference-materials/ecu-pinouts-28667/ (its about half way down, but you will have to register to view it, i'll see if i can get it to post)
ecu's to choose from:
http://hondaswap.com/reference-materials/honda-ecu-list-29129/
also try what kyle said and search/post in the engine management section. some of the guys that look mainly in there, "might" have more info for you.
edit: refer to the attachment
ive never heard of a jdm d16a from am ek. but i allways learn something new everyday.
1 - 20 of 22 Posts
