1 - 7 of 7 Posts
1997 CRV & Civic CX
Yes and Yes.
Thank you btw gearhead98
What about my ECU both engines are obd2a
I though about a d15b vtec as they are only $100 more but the 3stage vtec ECU are hard to find it seems
what would I require to swap a d15b Vtec obd1
ECU + odb2 to odb1 conversion harness
can I use my stock wiring harness and wire in the vtec ?
I have a rough budget of $1100 for engine and any required parts so I am looking for either a direct swap such as the D16a non vtec or a vtec swap that requires little wiring to be done
Harness and ecu from the car the engine and transmission are going in. I would not use the harness that comes with the engine, it will most likely be cut anyway.
Your car is a 97 cx, you will use the obd2a harness and ecu.
B-series Destroyer
4g 4d civic
Yay, useless thread bump #2
Love the Civic
See here's a problem when a thread doesn't get finished off by the fix, we get a bump years later by a n00b trying to help.
1 - 7 of 7 Posts
