1 - 3 of 3 Posts
d16y7 13g turbo, internally wastegated to 14 psi via spring.
How hard is it to go to an external wastegate? can i disconnect the internal one?
any recommendations on wastegate size and brand (cheaper is better, low budget.
setup is the turbo bolted to an hf (or hx) manifold with a 4 bolt flange. how would i set up an external wastegate?
That's what i did just weld your internal closed and run external out your 02 sensor and weld it. I ran 10 pounds on godspeed external it lasted 3 years then had to replace it.The seals went bad had boost creep. Damn waste gate.
1 - 3 of 3 Posts
