1 - 14 of 14 Posts
Hello i have a extra block laying around an i am board so i decided to build my bottom end. But before i do so i had a few questions. I am looking for more hp like always with out sacrificing blowing up my block.
(Just say forged pistons an eagle rods will be used)
1) i would like to sleeve an bore my block do i need the sleeves? I think its a good idea so i dont blow my side wall out. Other wise i read i need block guards.
2) if i bore my bottom end do i need to do anything to my top end besides building it? An if so whats a good idea?
My goal is for about 350-400 hp max an engine needs to be cleaned up an polished but sleeves i wanted to make it blow up proof on my part becuase i am good at killing engines.
Look into CSS
To me its better than sleeves and will make your HP goal safely for about $400
Theres a few very detailed threads here recently. I believe they still have a ZERO failure rate, which is fvcking unheard of and a true testament
Well.......
Ok i am gunna do 75.50 9:1
Compression with 14psi no sleeves or gaurds
irrelevant
You need to read, read some more, then look at other folks builds, then make some intelligent decisions, then ask question.
From the sounds of things you have 0 idea what you are doing.
Also if you would have looked in the showcase area of the forum, you will see plenty of builds putting down 300+ on stock sleeves
What are your goals?
What turbo are you looking at running
what cam?
QWho is going to tune it?
Fail Bot Fails
A friend of mine at a tuning shop is helping me. He specializes in honda engines so i shouldnt have any problems
Yeah well to be totally honest this forum helped me 0% talking to a real guy is easier that thro a computer screen witch u could also be telling me false info.
Well.......
what cam?
Fail Bot Fails
You have yet to answer any of these questions that have been asked. Just incase you havent figured out we do not read minds, if any of us did you think we would be on here.
You lack of info show your lazyness and not everyone around here is going to spoon feed you.
How about you do what is in red. That will get you the most info if you do what is posted and not just part of it.
All i am trying to do on this form is look for advise but you all make it a headache
none of us are willing to help someone that aint willing to help themselfs.
It took more time for you to start a thread and provide very little info than it did to find the stuff below
http://www.d-series.org/forums/showcase/175753-k-whats-2013-single-cam-teg-build-thread.html
oh shit he is shooting for 300hp, if you pay attention to the 1st post notice how he provide a lot of info and his goals.
http://www.d-series.org/forums/showcase/161272-flips-darton-mid-build.html
flip went the sleeved route, but dtock sleeves have been show to handle up 600hp You could experiance a cracked sleeve at any time tho.
http://www.d-series.org/forums/showcase/203026-d16z6-turbo-quest-10s.html
oh snap, the title says it all. Pay close attention to his list of parts.
http://www.d-series.org/forums/showcase/193393-i-has-eg-2.html
Sentry is going for a cheap build. his specs are on page 2, post 23.
here better yet here is the link for you lazy ass to what I am looking at
Showcase - D-series.org
Then even at the top of the FI part of the forum there is a sticky
http://www.d-series.org/forums/forced-induction/77291-turbo-nitrous-faqs-info-look-here-first.html
Also if you would have looked you will also notice this
http://www.d-series.org/forums/forced-induction/131762-d-series-turbo-build-threads.html
now after looking through all of that, then ask intelligent question and I bet you will get more responses from other members
1 - 14 of 14 Posts
