1 - 20 of 30 Posts
B
i got this from research off somewhere else online.
General Specs for 97 cu in (1.6L) D Series
Bore................2.95"(75mm)
Stroke.............3.54"(90mm)
Deck Height.....8.347"
Rod Length......5.394"
______Compression______HP___________TQ
D16A6.......9 to [email protected]@5000
D16Z6.......9.2 to [email protected]@5200
D16Y8.......9.6 to [email protected]@5500
Torque Specs
Camshaft Holder 8mm Bolts.....14-15ft lbs
Camshaft Holder 6mm Bolts.....104 inch lbs
Camshaft Pulley Bolt.......27ft lbs
AEM Cam Gear Adjustment Bolts(3 of them)....15ft lbs..apply Loctite "red" to the three retaining bolts
Connecting Rod Nut........23ft lbs
Crankshaft Pulley Bolt.....119ft lbs(D16A6).....134ft lbs(D16Z6)
Cylinder Head Bolts for D16A6
step 1.......22ft lbs
step 2.......48ft lbs
Cylinder Head Bolts for D16Z6
Step 1....22ft lbs
Step 2....53ft lbs
Cylinder Head Bolts for D16Y8
step 1(bolts 1-10)....15ft lbs
step 2(bolts 1-10)....36ft lbs
step 3(bolts 1-10)....49ft lbs
step 4(bolts 1 & 2)....49ft lbs
Cylinder Heads...All D ARP Studs
Step 1......15ft lbs
Step 2......30ft lbs
Step 3......62ft lbs
Cylinder Head Bolt Thread Size and Pitch.....10mm x 1.25mm
Distributor Mount Bolt....17-18ft lbs
Flywheel Bolt........87ft lbs
Intake Manifold to Cylinder Head Nut..16ft lbs
Main Bearing Cap Bolt........47ft lbs(D16A6)..........Step 1...18ft lbs(D16Z6 and Y8 )
Step 2...38ft lbs(D16Z6 and Y8 )
Rocker Arm..D16A6
End Rocker Arm Shaft Cap..9ft lbs
All Others and all D16Z and Y8s..........16ft lbs
Throttle BodyNut.......14-16ft lbs
Timing Belt Adjuster Bolt.....33ft lbs
Valve Adjustment Nut....10ft lbs(D16A6)....14-15ft lbs(D16Z6 and Y8 )
Cylinder Head Specs
Valve Sizes D16A6 Intake......29mm Exhaust....25mm
D16Z6 and Y8 Intake...30mm Exhaust....26mm
Valve Clearance
Stock D16A6,D16Z6 and D16Y8 Cams
Intake.....007-.009" (.17-.22mm)
Exhaust...009-.011" (.22-.27mm)
Head Chamber Volume
D16A6......................38cc
D16Z6 and D16Y7.....34.6cc
D16Y8......................32.8cc
Throttle Body Sizes
D16A6..... 55mm
D16Z6......56mm
D16Y7......56mm
D16Y8..... 56mm
B
all you got to do is pull the same info from your helms or chilton, this is just compiled.
88 CRX
Useful, but most of the stickies are stuff you can't find in your manual.
yellow bar for me
viper blue 92 eg
not many torque specs are available in the haynes manuals. i say sticky.
:werd: I've seen that they show you HOW to do it, they just don't tell you... how much to do it.
Nice! Referenced.
Formally known as SPONSOREDCRX
yea, some of it is a little off, but for the most part its right
yeh those connecting rod specs must be wrong because i torqued them to 23ftlb and tried turning over but it didn't budge, was so tight that i ended up loosening the harmonic balancer bolt, can someon give me an accurate connecting rod torque spec for a y8?
95 ex coupe
very good post! im sure il be using this here in about a week when i get my motor ready to go together. and i say sticky
wouldnt these be the ones that go through the rocker arm assemblies to hold the cam down???? they all seem to be 12mm on mine with 10mm on the ends
1995 Honda Civic LX
i've always wondered the same thing...
See above...
You are correct! Just did a head on Sunday...definitely 12mm and 10mm.
nonvtak ftw
they speak of the actual size of the bolt which is calculated by the threads not the heads size. FYI
no shit....that actually helps alot...but kind of dumb in my opp. im not gunna measure the shaft itself when its just as easy to put a socket of the right size on it
so guys any idea on waht could be causing my seizing issues when the conrod bolts are torqued to 23ftlbs?
1 - 20 of 30 Posts
