i was wondering could you use y8 internals in a jdm d15? if so tell me what exactly i can use
9 92HATCHLOVA · Registered Joined Nov 12, 2006 · 15 Posts Discussion Starter · #1 · Jan 23, 2007 Only show this user i was wondering could you use y8 internals in a jdm d15? if so tell me what exactly i can use
ryan89crx · Lifetime Awesome Member '89 CRX HF Joined Dec 22, 2003 · 34,993 Posts #2 · Jan 23, 2007 Only show this user rods - yes pistons - no crank - no the rods are the same in each motor, so unless you are going with Eagles or some other aftermarket they arent worth changing out.
9 92HATCHLOVA · Registered Joined Nov 12, 2006 · 15 Posts Discussion Starter · #3 · Jan 24, 2007 Only show this user i meant 2 say z6 not y8 sorry
Dweezil · Registered Joined Feb 3, 2005 · 3,722 Posts #4 · Jan 24, 2007 Only show this user As long as your D15 is the VTEC D15B, the rods will work. If it's any other D15 then no, you can only use non-D15B VTEC D15 parts.
9 92HATCHLOVA · Registered Joined Nov 12, 2006 · 15 Posts Discussion Starter · #5 · Jan 24, 2007 Only show this user ok im wanting to build the motor to withstand boost daily driven what would be a good setup
