1 - 7 of 7 Posts
95 civic coupe
Hmmm... I wonder if this would be helpful all put in one, since we all tend to go all over the place to find sheets for each cam so here's a sticky. I was doing some studies about most used D-series cams on street/tracks last night and here's all the info in one... I am not saying these are all 100% accurate, but what the companies advertised otherwise. I won't bother finding specs of the regrinds since it might not all that accurate and i was mostly interested in billets.
Lets start with the stockers
D16y8
246/230 Advertised Duration
208/191 Duration @ 0.050"
393/369 Gross lift
110 Lobe Seperation
D16z6
244/228 Advertised Duration
208/192 Duration @ 0.050"
384/370 Gross Lift
D16a6
in/ex
Advertised Duration 222/224
Duration @ 0.050'' 194/196
Gross Lift 333/362
Lobe Separation 110
D15b7
Lobe lift Valve lift Dur. @ .010" lobe lift
I .198" .323" 224
E .165" .309" 226
D15b8
D15B8 CX 8V
Lift @ valve
In = .377
Ex = .358
Duration @ .050"
In = 220 deg
Ex = 200 deg
Crower 2 Turbo Cam
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 217
Duration at 050 inch Lift: 234 int./217 exh.
Advertised Intake Duration: 312
Advertised Exhaust Duration: 318
Advertised Duration: 312 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.430 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.427 in.
Valve Lift with Factory Rocker Arm Ratio: 0.430 int./0.427 exh.
Comp Cam 59500
Primary Secondary VTEC Exhaust
Valve Adjustment .007 .007 .007 .009
Max Gross Valve lift .300 .308 .479 .441
Cam Lobe Lift .1890 .1949 .2890 .2420
Adv Dur @ .006 Valve Lift 232 236 267 289
Duration @ .050 Valve Lift 190 194 231 229
Valve Timing @ .050 Valve Lift Opening 16- 18- 8 BTDC 45 BBDC
Valve Timing @ .050 Valve Lift Closing 26 32 42 ABDC 3 ATDC
These Specs are for Cams(s) at the following minimum Centerlines 110.0 115.0 107.0 111.0
Comp Cam 59300
2000-7200rpm
Adv. Dur. 256 Int./268 Exh.
V. Lift .456 Int./.428 Exh.
Centerline 107 deg. Int./111 deg. Exh.
Bisi 2.4
Top selling*street/strip/race Turbo camshaft profile with slightly lopey idle, with emphasis up to 8400 rpms. Takes 7-10 business days to manufacture from billet. Cam gears, and our pro valve springs/retainers are highly recommended. 0.440″ valve lift on the intake and 0.430″ exh; 252 deg duration on intake and 233 deg exhaust at 0.040″ Optimized lobe separation. Destroys all other competitors turbo camshafts, with a 80whp+ improvement over stock at 20psi, and improved spooling characteristics!
Bisi 3.6
New Pro race only Turbo camshaft profile with extremely lopey idle, with emphasis up to 9100 rpms. Takes 7-10 business days to manufacture from billet. Adjustable cam gear, and Bisimoto Engineering pro valve springs/retainers are required. 0.479″ valve lift on the intake and 0.459 on exh; 247 deg duration on intake and 233 deg exhaust at 0.050″ Optimized lobe separation. Ideal for 450whp+ setups. Professional use only, with a 84whp gain at 20psi…as documented by SuperStreet Magazine.* The best of the best...every 9 second D16z6 owner chooses this profile as their cam of choice
Blox 1
92-95 D16Z6 Specifications
INTAKE: 234° / 0.255”
EXHAUST: 212° / 0.213”
Blox 2
Not much info on this
Intake: 242 degree/0.268 inch; exhaust: 217 degree/0.240 inch
Crower Level 1
Engine Size D16Z6 & D16Y8
Valve Lash .006" intake and .008" exhaust
Lobe center 110
Rocker Ratio: Intake / Exhaust 1.6 / 1.8
Advertised Duration (.010") Intake at the Valve: Primary / Vtec / Secondary 293 / 288 / 293
Advertised Duration (.010") Exhaust at the Valve: Primary / Vtec / Secondary / 299 /
Duration @ .050 Intake at the Valve: Primary / Vtec / Secondary 197 / 220 / 197
Duration @ .050 Exhaust at the Valve: Primary / Vtec / Secondary / 207 /
Lobe Lift Intake: Primary / Vtec / Secondary .205 / .243 / .205
Lobe Lift Exhaust: Primary / Vtec / Secondary / .203 /
Gross Lift Intake: Primary / Vtec / Secondary .328 / .389 / .328
Gross Lift Exhaust: Primary / Vtec / Secondary / .365 /
Rocker Ratio Intake: Primary / Vtec / Secondary 1.8 / 1.6 / 1.6
Rocker Ratio Exhaust: Primary / Vtec / Secondary 1.8 / 1.6 / 1.6
Performance Level 1
Low RPM Idle
Peak HP 7000
Redline 7500
Crower Level 4
Camshaft Name Stage 2 - 3/4 Race
Camshaft Series Original
Engine Type 4 Cylinder
Lobe center 109
Advertised Duration (.010") Intake at the Valve: Primary / Vtec / Secondary 295 / 319 / 295
Advertised Duration (.010") Exhaust at the Valve: Primary / Vtec / Secondary / 310 /
Duration @ .050 Intake at the Valve: Primary / Vtec / Secondary 204 / 235 / 204
Duration @ .050 Exhaust at the Valve: Primary / Vtec / Secondary / 223 /
Lobe Lift Intake: Primary / Vtec / Secondary .205 / .270 / .205
Lobe Lift Exhaust: Primary / Vtec / Secondary / .242 /
Gross Lift Intake: Primary / Vtec / Secondary .332 / .432 / .332
Gross Lift Exhaust: Primary / Vtec / Secondary / .436 /
Performance Level 4
Low RPM 1000
Peak HP 7500
Redline 8000
Crower level 5 full retard cam
Lobe center 115
Advertised Duration (.010") Intake at the Valve: Primary / Vtec / Secondary 295 / 329 / 295
Advertised Duration (.010") Exhaust at the Valve: Primary / Vtec / Secondary / 317 /
Duration @ .050 Intake at the Valve: Primary / Vtec / Secondary 204 / 239 / 204
Duration @ .050 Exhaust at the Valve: Primary / Vtec / Secondary / 226 /
Lobe Lift Intake: Primary / Vtec / Secondary .210 / .276 / .210
Lobe Lift Exhaust: Primary / Vtec / Secondary / .260 /
Gross Lift Intake: Primary / Vtec / Secondary .332 / .442 / .332
Gross Lift Exhaust: Primary / Vtec / Secondary / .468 /
Performance Level 5
Low RPM 1200
Peak HP 8000
Redline 8500
I end up getting a Rocket Motorsports Billet Cam
It has longer durations than the Bisi 3.6 at 250 Int - 240 Exh. @.50
Hmmm.. In terms of Max gross lifts? Haha. I can't tell yet :single fuck:
Cam should be here next week.
95 civic coupe
Thank you for this information. What would be REALLY helpful is the engraving marks on the site of each cam for identification purposes.
95 civic coupe
1 - 7 of 7 Posts
